cast iron radiators
Mike T., Swampeast MO
Member Posts: 6,928
The ones that are connected only across the bottom can only be used with steam systems.
Those connected across both top and bottom can be used with either steam or hot water.
cast iron radiators
i bought an old house with steam heat and i noticed two types of radiators. one type, the tubes are connected across the bottom. the other type, they are connected across the top and bottom. does anyone know what the difference is between them. thanks for any help.bp.0 -
Radiators
http://www.heatinghelp.com/newsletter.cfm?Id=20
Cut and paste this link. Or just go to the top of the page, click "Hot Tech Topics" then scroll down "An Old Radiator Q&A"
Lots of great info.
Good luck,
JimThere was an error rendering this rich post.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
