Oil burner isn't starting...
Barrington White
Member Posts: 37
You can try T.F. Obrien in New Hyde Park. 1516-488-1800
Help please - oil burner
I just moved into a new home that is heated by steam fueled by oil. It got very cold in the house yesterday but I was unable to turn the heat on. The boiler is very old (maybe 25 years) and I know that the oil tank was just filled. There is a switch on the burner, which is in the on position. There is a wall-mounted thermostat in the house that has been turned to "heat" and has been set at 66 degrees. Still, no heat can be detected near the radiators. I tried turning the valves on the individual radiators as well, but that didn't get it going either. Any advice would be appreciated! I don't know what I'm doing...0 -
sometimes after a fuel delivery some condensed water may
mix with the fuel and be drawn up by the pump and clog the oil filter. on older systems it is somewhat of a common occurence, it is also possible with a one pipe system to get an air lock in the fuel supply.
you could go to the boiler and looking at the burner (gun looking thing } posh the little red button ,...just once.
if it doesnt go in a couple min.....turn the power off then back on...wait a min..push the red button again. if it doesnt Go it would be best to call an oil tech.0 -
What does the red button do? I'm very nervous that I'll break something or start a fire or something.
Is there a pilot light that I need to light?0 -
the red button makes it go.
and , no you positively do not want to start an oil burner with a fire ..there is a transformer within the burner that has a heck of a jolt to it, and if the fire box became loaded earlier , the boiler can behave badly.0 -
Thank you... I'll give it a look when I get home.0 -
no heat
There may be an emergency switch that is off, if the unit is in the basement it could be at the top of the stairwell or upstairs by the door to the basement. Also check the fusebox, the oilburner should have its own cicuit0 -
a little more
Definitely would be a good idea to have a service technician check out the system and also show you the ropes of a dealing with a steam system, it does need a bit of regular inspection/attention from the homeowner. And check out the books on this website pertaining to steam heat, loads of good info for consumers and professionals as well....
Pat0 -
Thank you. I think I am going to call a local company to help us. I want to understand how the system works and be able to use it properly. I appreciate all the advice!0 -
no start steam boiler
You might also check to make sure there is enough water. Not enough and no start0 -
It seems to be all set now - the motor was cracked. Other than that, the technician who came out to fix it just showed my husband how to operate it and it seems to be working. Thanks!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
