boiler leak
Not a good idea, but you might try some boiler sealer if the leak is very small. If the boiler is not equipped with a low water cut-off, I would shut it down immediately. You are living on borrowed time. Find a way to replace it sooner than later.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • GusHerb
    GusHerb Member Posts: 91
    boiler leak
    hi all is it ok to run a h. w. boiler with a pinhole leak in the heat exchanger. it has an auto filler to keep it from dry running. im replacing the boiler within the month.
    thanks jon
