botched radiant heat job
Al Letellier_9
Member Posts: 929
I see many of these in my consulting business. Yes you may be able to use telestats, but you need to know the heat loss and temps required. If that info is not available from the owner, the installer or the supplier, you should "reverse engineer the job" to find out what you need for temps. You may not be able to "see" the tubing in some cases, so you will have to SWAG (scientifically wild **** guesstimate) what may be in place. Whatever you do, make a written agreement with a disclaimer that you are not responsible for the work of others or the consequences of a bad install. If you don't know how to do this, either get your lawyer to do it or walk away from the job. You will own it if you touch it.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Called in on job where contractor kicked off job.Job is 95 % done but it is un completed.Entire house radiant heat two pumps installed with two thermosatic mixing vales.Each of the two floors have there own maifolds.Howerver both floors have a mix of stone floors and hardwood.Is there away now that the tubing and manifolds are inplace to regulate each temp.I would be able to pu telestats on each loop,wires arein place for that.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
