I think you've seen this before ( s milne )
but if they were up here before , they sure are worth putting up again .
Scott , looks like your company uses a few different brands of boilers and indirects . Do you have a good - better - best choice for you customers ? And what are they ?
But here's a Buderus GB JCA did
last summer.
The owner had a gas boiler in a four foot crawl under the house. His DHW was a off a coil that had a storage tank under the stairs.
We put in a GB with a Super-Stor.
AS Chris said, he was there installing the RM-10 when the owner opened his gas bill. " This can't be right ... ". What untill Jan.
Scott
Nice Job, JCA!
A tight closet, yet everything is accessible!
Did you guys originally intend to pipe this pri-sec with closely-spaced T's before changing your minds? The stubs I see on the supply line suggest that...
Anyway, I like the layout and that all the pipes can be insulated because they're stood off, yet well supported. Looks like you had a lot of fun with the pro-press...0 -
Ron
its pretty much Buderus witha Viessmann thrown in when I think it fits the job.
No leads from slick salemans or marketing ploys, just a craftsman who belives in the products he sells.
Thanks as always
Scott
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
