Mod Con Replacement Boiler - Old System
the manufacturer's instructions as to near-boiler piping principally. Beyond that, understanding the entire boiler, piping, radiation and controls as a <i>system</i>.
For example, knowing what your radiation potential is versus your heat loss, avoiding bypasses and short circuits that might increase return water temperature (the coldest return water is the best for efficiency).
If you have multiple zones using the same temperature, assuring that the flow rates from one does not quench condensing for one thing. Knowing the hierarchy of temperatures is critical if you have a multi-temperature system.
Cleaning, flushing and treatment as mentioned, purging.
Those are a few "keys". Requires thinking a little differently if you are used to dealing with cast iron boilers.
