Tankless Electrical Domestic Water Heater
Scott Gregg
Member Posts: 187
Steible Eltron.
Siesco had a very bad habit of becomming a warm water sprinkler system around here.
If you need over 2.5GPM of hot water in the winter, figure out how to get LP gas in your house and go with Noritz.
Hello,
I'm looking for different manufacturers of Electrical Tankless Water Heaters. Can you guys throw out some names. The only two that ive come across are Takagi and Stiebel Eltron. Are there any bigger name manufacturers out there?
Thanks,
JBW0 -
Eemax is another0 -
electric tankless water heaters
What is your application? Stiebel Eltron makes some fine heaters. However, their larger units draw alot of KW's.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
