replacing r8182d
Al Gregory
Al Gregory Member Posts: 259
There is a trick where you can remove the yellow wire and insert the wire on B1 into its spot. Then you can put a cad sell control on the burner. There maybe other issues though.
  • jack kowalczik
    jack kowalczik Member Posts: 5
    by-passing r8182d
    Hi,my question is if only the K-2 relay isn't pulling in on my R8182D control,but if I hold it in manualy it boiler runs and cycles fine.Can I use the r8184g and wire it into the r8182d. thanks Jack
