Polaris Or Boiler?
Al Letellier_9
Member Posts: 929
As in Maine, the Polaris is not a legal installation in some states. You must separate the domestic water from the heating water. Check your local codes on this issue.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Need advise on what to use for heating the water in a new house with radiant floor heat. Only interested in 90% and was going to use the Polaris water heaters but have read some posts saying they were having problems with them.
Thanks for any help.0 -
If you already have radiant...
There must be a boiler somewhere involved?
Why not simply use the heating boiler and connect it with an indirect domestic hot water maker? Typically, add a dedicated zone to what's there, install some form of D/H/W prioritizer, and let 'er rip?0 -
The Polaris can stack up favorably in efficiency to a conventional boiler, though I don't buy its efficiency rating as listed. They must be run at 140-160 to avoid condensing or they will short out their igniters on a regular basis, which means it's not condensing, which I believe means it's not running as efficiently as it should.
For the price, you can get a modulating/condensing boiler that will do a much better job. The Polaris is completely obsolete in my book, now that we have mod/cons. the mod/con will also be silent, which the Polaris most definitely cannot claim.0 -
Mr. Dolittle...
I would suggest that the advice given by NRT. Rob and Al Lettelier are (is?) right on the money. Mod/Cons were not around when the Polaris came on the scene. As far as I know, NONE of the Dual-Purpose Heating/Domestic Water Heaters have passed muster over the course of time. Please look at what is out there TODAY. Good luck.
I've had good luck
with polaris and external HX. Running 140 DHW and a flat plate for raiant.
Think I would look into the hew HTP Voyager tank with internal HX and 925 burner. A much better match and designed and listed for your use.
I've heard the BW CombiCor has been re-worked with a large steel coil. Less $$ but not quite as efficient as a condensor.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Thanks for the help, this is in a new house. Sounds like most think the mod boiler would be the way to go. There will be several sq. ft. of laminate wood flooring and I need some idea of how hot it can be but it sounds like the Polaris would be a bad choice. The boiler is for radiant only.0 -
Any parts for the Polaris are ridiculously high priced...so much so that I can't get a parts house to carry them...so if it quits...parts are at least next day air freight from the factory...which here in Alaska means 2-3 days of shivering.0 -
Another option
might be one of the combo boilers that are being offered by a few manuf. These are H stamp certified boilers incorporating a flat plate HX for domestic hot water production. Flow requirements on the domestic side are limited (between 3 and 4 gpm), however with a little conservation of hot water needs, these boilers are very cost effective.
- 125 Chimneys & Flues
