low water cutoff
Jorge
Member Posts: 26
It`s on a mc lane hot water boiler cga5. Just put it in last week in my home. It was working ok all week then today the red light went on. I checked the wiring and the water in the system and it`s all ok. I jumped out the cut off and ran the boiler all ok. It seems that when the boiler heats up the red light goes out so I tried bleading the system there was on air in the system.
low water cutoff
Any one have a problem with a 24 volt guard dog low water cutoff saying that the water was low when it was ok.0 -
Rich.............
new one on me, what`s it on?0 -
It`s on a mc lane hot water boiler cga5. Just put it in last week in my home. It was working ok all week then today the red light went on. I checked the wiring and the water in the system and it`s all ok. I jumped out the cut off and ran the boiler all ok. It seems that when the boiler heats up the red light goes out so I tried bleading the system there was no air in the system.0 -
Rich
Did you mount it in a Horizontal pipe if so and that pipe gets air in it the LWCO will woark and shut down the system, I always mount in a vertical pipe and try for the suppy side.0 -
No it is vertical. It is in the outle side of the boiler. First is the guage then the lwco then a ball valve and 1 foot of pipe then a 90 elbow to a honeywell air trap then to the two zone valves.
see pics0 -
LWCO
Did you put it in with teflon tape?
Is the green ground wire attached?
Yes it said to use teflon tape and the ground wire is grounded to the transformer box inside the boiler. I tryed putting the ground wire on the pipe it did not work.0 -
Rich, just a guess.............
what`s that, on 1" pipe?, maybe its screwed-in too far and "shorting-itself-out" against the body of the fitting?0 -
Not sure about the Guard Dog
but my brothers unit ran for months and one day it wouldn't start Friday at four pm we get he call, I go over and no power out of the safeguard LWCO I looked inside the control and the installer never hoked up the white wire to the post, they just rested it there and bing no power once it moved enough.0 -
Maybe this will help...
below is a link to a W/M .pdf file that pertains to the RB-24 LWCO:
http://www.weil-mclain.com/contractor/TechServiceBulletins/sb0302.pdf0 -
check your grounds
Backfedd on a ground or lack of a good ground on the system will cause this0 -
water hammer
I have water hammer whenever the zone valves shut. They are honeywell zone valves and they are mounted on the feed side of the boiler.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 919 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
