RoosterBoy Install Pictures
jack z_2
jack z_2 Member Posts: 15
Your stove installation looks fine. Your attic insulation is installed wrong. The kraft paper should be installed next to the heated area. You have it reversed.
  • RoosterBoy
    RoosterBoy Member Posts: 459
    put in a new heater in my house check out my install
    thank you
    Jason
  • Weezbo
    Weezbo Member Posts: 6,232
    catalytic are cool :)
    wheres the outside air for the combustion?
    is it the floor grill on the left of where you are standing?
    i tend to recommend bringing the outside make up air under the free standing with an opening close to the front.
    there is an additional gizmo that you can lash into the stack....which looks like a coffe pot / flour sifter ...it reduces stack to very low temps and reduces particulates by collecting them out of the previous combustion process. you can remove it close a little slider door ,clean it with the sifter squeezer handle and put it back from whence it came... i wish i knew who made them they have been around for a while...
  • Josh_10
    Josh_10 Member Posts: 787
    I think I see it if front of the cradle. Or are my eyes pulling a trick on me?
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,557
    I think that's the diaper pail.
  • wondering what
    Wondering what does the cannon do at the base of ur fireplace? Does it fire automatic when the fire get low? Otherwise, its a nice installation!
  • wondering what
  • ScottMP
    ScottMP Member Posts: 5,883
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,563
    Tower
    What is the tower in the back yard used for :)
  • the radio tower
    I'm sure after reading "thanks, brad white" post, Jason want Scottie to beam him up.....
  • RoosterBoy
    thanks guys yes the insulation was installed wrong and some day i will be up there to fix it i will also stagger the seams
    when i flip it around.
    thank you
    Jason
  • Patchogue Phil_29
    Patchogue Phil_29 Member Posts: 121
    insulation
    Is that pink-stuff insulation a second layer or is it the only layer?
    If it is the only layer then flip it over. If it is a second layer, then you *should* peel off the kraft paper or get unfaced batts as a second (or more) layer in an attic.
