Adding zones
Adding a zone is done all the time. If you current Monoflow zone works well, do not mess with it. Add a second zone in parallel with it's own circulator.
This is a good time to check and make sure that you are "pumping away" from the expansion tank, but otherwise the addition of a zone is routine surgery.
When designing new systems, I always install a set of valves for future; cheap insurance and less hassle than a drain-down to add later.
  • Will Merryman
    Will Merryman Member Posts: 32
    adding a zone
    Hi, I was wondering if it is possible to add a zone or two to my existing boiler. It is a Burnham V-1A series.It is hooked up in a monoflow configuration.The house size has not changed. The only changes are spray foam insulation and new low e windows.I want a separate zone for bedroom underfloor heating using the ultra fin product.I am told this system can use boiler temp. water.I could add in a mixing valve to be on the safe side.
    Any help would be appreciated. Thanks in advance.
    Will
  • Will Merryman
    adding a zone
    Hi Brad, Thanks for the reply to my post on heating help. I searched and found the info on pumping away and will try to determine my setup. The forum is a great place to learn and it seems that the various posts I read were very informative.I will check back from time to time just to see what is going on.
    Will
  • Contractor
    Contractor Member Posts: 41
    Spray Foam
    Be careful using the spray on foam, if it not applied according to the manufacturers guidelines (1" at a time) temperatures can reach a temp that can blister the PEX. Just a warning.
