price
mikea23
Member Posts: 224
how many guys bid residential plumbing per fixture and what do you think a fare rate would be I have heard anything from 600 to 1400 we currently do take ofs on everything but alot of times it just takes to long
Mike
Mike
Sounds like what a skorched air guy would do
As in price a job by a certain $ per ton? might work in cookie-cutter houses. I wouldn't do it myself.Too many variables.0 -
walls
not only price per fixture , but walls also.
i.e you can have three fixtures on one wall or three walls with
a fixture on each. The latter being more expensive to rough-in.
I try to look at each install individually.
Do a complete material take off first. Then bid on your material. You should figure out how much time it takes to glue together a Santee including drilling and how much time it takes to run 20' of 3" PVC including hanging. Then you can plug it all into an excell spreadsheet and enter in your materials for all jobs and get a fairly accurate estimate.
Of course there are always variables especially on retro-fitts. Don't forget to add in travel time and extra time for impeded access.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
