Fuel Lines for Biodiesel
Glennman
Member Posts: 2
I'd appreciate recommendations on fuel lines carrying biodiesel 20%(B20). Copper and 100% biodiesel are NOT compatible. While copper appears to be more compatible with B20 than B100, B20 has only been around for a few years, and I'm expecting tanks to last 20-30+ years.
Can anyone recommend fuel line options (including any suggested double wall piping)and reasonable ways to monitor the containment pipe?
Thanks, Guys. Gman
Thanks, Guys. Gman
I'd appreciate recommendations on fuel lines connected to an inground tank holding biodiesel 20%(B20). Copper and 100% biodiesel are NOT compatible. While copper appears to be compatible with B20, B20 has only been around for a few years, and I'd expect the tank to last 20-30+ years.
Thanks, Guys.
Gman0 -
piping....
> Can
> Thanks,
> Guys. Gman
Piping ....
I'm about 30 feet away from a fiberglass pipe in a pipe system. What they did was glue the pipes one inside the other and as each dropped into the building and tank area they used a rubber reducer coupling (fernco brand) to enclose the end, thus creating a enclosed chase that could be checked for leaks. This has to be done in a warm place or heated properly for the fiberglass to cure. I wonder if it may not be best to just run it in black T&C and coat the piping. I have seen many old, old black pipe supply and returns that have been buried for years. Best Regards, Gman0 -
Thanks, blackoakbob! What's black T&C?
How about running old black pipe inside PVC. Coming into the house, if the black pipe were vertical, you could put a PVC T on its side. The black pipe would then turn at right angles and therefore be horizontal. Any oil would continue to run down the vertical drop and into a small tank with a sensor (or float) that could be connected to an alarm. Thanks. Gman.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
