Secondary circ. sizing
JK_5
Member Posts: 2
I've been told I can size my secondary circulators for a 40 deg delta T to reduce pipe sizes & circs. Just want to confirm. I have 2 300mbh(Weil PFG7's) output boilers and have selected NRF33 11/2"(aprox 16 gpm @ 10tdh) for my secondary pumps feeding into my primary loop. Any problems in doing this.Input is greatly appreciated
Can your emitters
handle a 40 degree delta T, and have suffecient output?
Perhaps with a low temperature radiant and VS injection you could run a 140- 180 boiler operating differential.
I've pushed a few dual cast iron boilers into a 30 degree delta t on a VS injection radiant that Siggy helped me design.
Also be sure the boiler manufacture approves of a 40 degree delta t.
Be sure to have a smart boiler return temperature protection device if you plan on running down the 140 range.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
