New steamer with drop header
I like the "flow" of the riser to drop header, sort of a sea serpent. I bet it is nice and quiet and as you said with the gas gun, quiet.... Nice pipe joints too as Ray pointed out. No wrenches? So hand tight will hold them? Neat.
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    This was a fun one
    I pulled out a old HB-smith, and put in a W+M with a carlin ez-1 gas burner . drop header made the job look good.
    I looke at this job in may, did the load on it and checked every rad , made sure the valves were ok and vents were ok, fired up the boiler and found out someone removed a vent off the rad in the kitchen.....OOPS...;-)
    David
  • Todd_12
    Todd_12 Member Posts: 55
    Nice job!
    Just curious, why use the powergas burner?
  • David Sutton_6
    Hello Tom
    Using the gsa burner adds about 6% more eff to the system, and i think it makes steam alot faster. also if ever they want to change over to oil it will be very easy to do so....David
  • Ray Landry
    Ray Landry Member Posts: 203
    David nice work as always! What is that purple pipe dope you are using? Looks like it beads nice without much of a mess
  • David Sutton_6
    Hi Ray
    it leak-loc , two thing i realy hate...pipe dope all over the fittings and pipe and wrench marks on the pipes. i never put a wrench on the pipe unles i have no option.when i put on the dope its a fine bead around the last 2 or 3 treads, there aint a hole lot of room between them there treads so i feel there is no good reason to paint the treads with a couple of coats of pipe dope ;-)
    Thanks Ray !
    David
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Dr.Pepper
    I am beginning to notice a pattern here David.
    Nice looking install!
    Mark H
  • No pipe wrenches,... Shaking hands with you could prove to be crippling!
    Seriously though, Just hand tight steam with no leaks?
    You must use a wrench below the waterline yes?
  • The Kid_2
    The Kid_2 Member Posts: 19
    Mallable fittings
    Just wondering why the mallable fittings over the cast iron ones. I only used cast iron on steam all the steam systems that i have ever taken out also put together with cast fittings...just wondering...
    The kid
  • What makes
    malleable fittings a bad choice of material on steam ?
  • Gret pipework Dave
    Very well thought out near boiler piping . How is the noise with the gas gun compared to an oil burner ? I like that you protected the pressure gauge with the pigtail . Little things like that show you are true craftsman .
  • David Sutton_6
    Hi Ron
    The main use for the cast wa so it can be broken, the mal's make a tighter fit and cost less,
    You ready for another fun winter lol....David
  • David Sutton_6
    Hi Brad
    i us pipe wrenches , but just on the fitting and try to spin on as much as possible before pulling.
    Go to the vidio's and look at the one on bent pipe wrench, you can see how i tighten up a fitting.
    Thank you Brad!!
    David
  • Haha , who needs winter ?
    23 boilers in 25 work days . I need vacation . Yeah I knew the answer about cast vs. malleable . I'm still trying to find out why people think it's a bad choice for steam .
  • The Kid_2
    Fittings
    I'm NOT saying that it's good or bad...Was looking for a why..SMART ****
  • David Sutton_6
    no need for that Kid
    trust me Ron jr was not being offensive he's a very good person,
    i hope i ansewered your question and thanks for wanting to know...
    David
  • The Kid_2
    no problemo
    by all means there is no problem.....
  • gerry gill
    gerry gill Member Posts: 3,078
    very nice
    its always a pleasure to look at nice piping work..well done, very nice.
    gwgillplumbingandheating.com
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Sweeeeeet!
    One question: Is the EZ-Gas available from W-M as a factory option, or did you engineer that yourself?
  • David Sutton_6
    hiya Frank
    Not a option fro W+M, but with 2 weeks notice carlin will OEM a burner to plug and play, this one i had to refit for the boiler and set the orifice myself . the burner runs great! this burner is so much niceryou can see it at carlin's web site
  • Who , me ?
    Believe me , the Kid , I'm not trying to be a smart **** , so just take it down a notch . You did write you only use cast iron on steam . Other than the fact that all the steam systems you replace had cast fittings , was there any other reason you don't use malleable ?
  • PSSSttt, Kid...
    Look around. See anyone else calling other people names? No? Ya know why? Because everyone hanging out here is very civil.
    Learn by example...
    You can't catch many flies with acid.
    Stick around, ya just might learn something you can use, including civility.
    ME
  • David Sutton_6
    hi Gerry
    Thank you !!!
    David
