Peerless SC-07 versus Weil Mclain 480
Diar
Member Posts: 50
The Peerless SC-07 makes 1446 sq ft of steam using 26 gallons of water, while the Weil Mclain 480 makes 1236 sq ft of steam and uses 36 gallons of water.
I'm wondering if the Peerless would be the better choice, due to its low water content. Is the seasonal efficiency of the Peerless better than the Weil Mclain because of its lower water content? Are there any issues with having a water content of 26 gallons for 1446 sq ft of steam? If so, can these issues be easily addressed?
Any other opinions with regards to which boiler is better ( and whether there is a lot of Peerless steam knowledge in the Boston area ) would be appreciated as well.
Thanks,
Diar
Thanks,
Diar
Space Requirements for the Peerless SC Boiler vs Weil-McLain 480 Boiler...The 80 boiler has a large steam chest to make nice dry steam....Look at www.weil-mclain.com
go to 80 boiler manual and read the users guide...
As the Peerless Rep in New England, I can assure you that there is plenty of knowledge available. Call us at 978-667-6399 for more information or if you have any questions.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
