T8000
Dave_23
Dave_23 Member Posts: 190
Bill from Honeywell,
Where can I purchase a T8000 for a steam system There is no need for air condtioning/cooling system control from this 'stat, just my steam heat. What is the exact part number, with all suffixes, that I should order? Also who are your dealers in the 48201 or 48230 areas?
Part 2 - Do you make a T8000 or eq for a cooling-only systems (Such as a SpacePak add-on to a two story steam heated home) Where I live in Michigan, the cooling stats for add-on systems are usually located on the second floor, whereas the heating stat is on the first floor in the dining room.
Can I call you with questions, if necessary? If so, please email me your contact info.
Thanks, Dave
