Sizing
hr
Member Posts: 6,106
the Slant Fin program will provide you with the BTU/ hr loads for the rooms. Contact the panel radiator manufacture for output tables, generally based on various supply temperatures. Many manufactures have this info online. Burerus, Dianorm, Myson are a few of the brands mentioned here often.
Match the panel radiator to the room load based on the supply temperture you plan on providing. TRV's are a nice way to control room by room panel rad systems.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Sizing radiant panels
If I use slant-fin program for my heat lose can I sizes radiant panels with the room by room break down or do I need a different program.0 -
Home heatloss
is one thing, most calculations use the IBR method for whole house, or individual rooms. Depending on the radiant system you are going to install, as they are different, I would suggest their method for matching-it.0 -
TRV
I am looking at buderus panels. Are the TRV valves the dial controls I see on their brouchers? If not where can I go to see proper installation of the valves?0 -
Danfoss makes a nice TRV google Danfoss
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
