uponor mulit core
John Barba_2
Member Posts: 92
Here's a PDF of the install manual. Let me know if you need info on the press tool.
Thanks...
JMB
Thanks...
JMB
anyone know....
where I can down load info on preparing mulit core connections for wirsbo/uponor tubing...I have special some of it for a job but the supply house has no info on installing it....ty, kpc
john....
that is a step in the right direction...but I have the crimp style fittings w/ the o-rings....the pdf file only shows the qs style fitting.... ty,kpc
Kevin
Chamfer it the same as you would w/ the QS fitting, push the fitting on until you see the tube thru the little hole on the side of the collar and crimp.
Do have the hand crimper or powered ?
it came w/
2 o-rings 1 grey, 1 black where do they go on the fitting? kpc
baseboard ells
Must be the baseboard ells. The heavy gray one all the way at the bottom, the thin black one at the slot closer to the top. Then snap the stainless steel sleeve into place, so it snaps over the heavy gray o-ring at the bottom -- it's the only way it will stay on! Champfer the tubing, slide it in all the way till you see white in the "witness holes" all the way around. Then place the press tool over the stainless steel band, and press. I'll see if I can find a multipress sheet on our website for you.
JMB0 -
Here it is...
pdf of multipress fitting. Enjoy...0 -
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
