Hot Water Cast Iron Radiator Leaking
Tim_35
Member Posts: 1
Hot Water Cast Iron Radiator Leaking JUST a little, any kind of sealant etc.? that I can fix that with.
I have the same problem
in a newly installed cast iron radiator. How 'small' is the leak? In my case, it's one drop every 3 or so minutes and over a few days, it appears to have automatically sealed itself. But, I just wanted to share, I'll leave the real reply to the pros on this site.0 -
Where is it leaking from? Has anyone replaced anything on the rad? New nipples? Air vent?
Tim
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Just a guy running some pipes.0 -
I'
> vent?
> Tim
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 387&Step=30"_To Learn More About This
> "Find A Professional"_/A_
I'm sorry for jumping in since I am not the original poster
but, in my instance the leak is around the new brass bushing that was installed onto the radiator to connect the radiator to 3/4" copper pipe.0 -
The valve tailpiece is installed with a spud, or dog wrench that fits into the tailpiece and tightens it from inside to not damage the mating surface of the tailpiece. If it is leaking, it will need to be removed, taped, doped, and reinstalled correctly. Do not try stop leak products.
Tim
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
