dropped header
RMA
Member Posts: 55
need some help on dropped header for steam boiler. Never did one, but have heard of it. Any body out there can help?
Thanks RMA
Thanks RMA
its the same guy
Its the same guy question the importance of the near boiler pipings, are u a homeower?0 -
RMA
Look back at your last post ,Steamhead added a link to drop header info....David
Does it make a difference ?
Do you have some problem with RMA and his questions ?
RMA , I've been dropping my steam headers since Noel Murdough posted the first drop header pic on this site . I truly believe drop headers separate any water carried up the riser pipes alot better than no drop . And it gives you that critical 24 inch height if the steam main is lower than 24 inches to the water line . Theres plenty of pics in Dan's Library . Look under Drop Headers . And you can do a search with those key words .
I for one don't mind giving you advice on steam piping , whether you're a homeowner or pro . What brand boiler are you considering ?0 -
if you can't add anything positive, don't add anything
rma0 -
Thanks to david sutton and ron jr.
RMA0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
