gas boiler replacement
Bill Nye_2
Could yer go tru da roof? How 'bout if you put the water tank on the bottom, the boiler on the top, and vent up through the roof?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=351&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
looking for suggestions
I have a customer who need's a system replacement. It is presently a Weil Mclain CGI gas boiler which as you can see in the pic's is not to code. The venting requires 6' from an inside corner and 5' from a overhang. I have limited space inside the boiler room (if you want to call it that). I am looking for a way to replace this, make it to code and not have to do a large reconstruction of the area given. Any suggestion's on a system that could fit into the given space?0 -
Three
Wish I could but have 3 skylight's just above where I would pass through the roof...Sorry should have mentioned that. Also I am dealing with an association who want's little or no changes to the existing "style" of the property..To include venting terminations..:(0 -
Electric heat
Electric heat, you won't need a vent! Only kidding, I love association people who worry more about "looks" than function and safety
- 133 Chimneys & Flues
