Cv ratings
antman_2
Member Posts: 1
Is the Cv rating of a valve the maximum flow rate allowable through it?
Cv Ratings
The Cv rating as commonly used in the U.S., is the flow rate through a valve (or other device) in Gallons per Minute at a pressure drop of 1.0 PSIG (2.31 feet of head).
And
The head loss through the valve at a given flow rate is: hl=(1.52*gpm/Cv)^2
-Andrew0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
