New Boiler Pic
Moses
Moses Member Posts: 92
Hi Wallis.
It has been a long time since I posted on the wall some pictures of my work. This is a new 6 story conodo. Each floor is about 1800 s/f. I tried very hard to convince them to go with radiant heat, but to no avail. The 2nd. option was to go with cast iron radiators. We chose the Mascot wall hung boiler, made by Laars,which is rated 96% efficiency. We build our p/s header right under the boiler. The boiler comes with a build in pump,we used it as our injecting pump into the header. On the supply side we installed 2, zone valves, 1, for the front, and 1, for the back. We had to installed addtional 15 gal. ex-tank. Each radiator is connected to the manifold with pex tubing, home-run,with balancing valves/shut-off valves
See attach photos
Moses
