reversing flow direction on a series loop
Al Letellier_9
Member Posts: 929
In principal it should work, but in theory, you should do proper heat loss for each room and determine the need vs. output at design temp. Go figure!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have a series loop fin-tube baseboard zone with oversized radiation on the first part of the loop, and merely adequate radiation on the last part.
There will be an opportunity during a repipe to swap ends, thus putting the warmer supply water through the adequate rooms first, then the overradiated room last.
Presently, this loop has a decent delta-T so it would seem there's a benefit to flipping the flow direction.
Any downside to this? Seems to make sense at first thought.
Thanks.0 -
Did it
Thanks Al. That's the very reason I posed the question. The load calcs for various supply temps vs. ODT say it's a winner.0 -
Can you split it?
Intercept the return from the mid-point with a home-run and have two separate zones, one reversed from the original flow direction, the other remaining the same.
This will dramatically reduce the pressure drop (by 75% if of equal proportions) and give better control/satisfaction to more spaces.
Just a thought.0 -
cantilevers, walls, and cabinets, oh my!
Not easily.... Neat idea, though.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
