Gas Fireplace
Aaron_5
Aaron_5 Member Posts: 4
I want to take out the 1978 gas fireplace I have in my house. The round metal pipe extends from the top of the fireplace up to the ceiling without touching any walls. Once I remove it all I want to seal off the pipe on the inside and drywall over it. I want to leave the part sticking out of the roof intact in case I decide to install a new fireplace in the future. I have seen a tee cap online which looks like it might work, but I cannot find where to purchase one. I measure the pipe inside my house and it is 22" circumference. Lowe's only has a 6" diameter which is too small. Without busting out the old high school geometery I am guessing I need 7-8" diameter.
Any help is greatly appreciated.
  • Aaron_5
    Inside Chimney Cap
  • c.t.kay
    c.t.kay Member Posts: 85
    cap
    divide 22 by 3.14 to get the diameter.
  • Aaron_5
    Gas Fire Place
    Thanks, but what I was actually looking for is where to purchase a cap to seal off the old chimney.
  • Bob Harper
    Bob Harper Member Posts: 1,119
    22\" circumference=7\"
    However, if you find any ol' cap/plug and seal the base of the B-vent, you could get condensation in there. Once it fills up a little, you can get ceiling damage or start growing "goobers" in the walls.
