Ready made panels
DH
DH Member Posts: 21
Depends on what your needs are. Majority of systems are component installs, however you do have lots of great pre-built panels available these days. Not sure where you are located, but you should check out the latest products that Danfoss Panel Division located in Calgary, Canada have to offer. I have over 30+ contractors in my territory that have installed panels and are seeing the benefits of the offerings. If you want to check them out, you can call Duane Spielman @ Danfoss (1-403-236-9560). I believe they have a toll free number as well. Maybe one of the Danfoss guys could provide that on this chat. I am sure they can get you some information to you.
  • Rick_7
    Rick_7 Member Posts: 2
    Ready made panels
    What's everyones thoughts on ready made panels (pump/contol)vs. build your own ( other than cost) any exp. good or bad. Also considering using Buderus GA124 or GB142 any exp with these?
    I've used Burnham and Slant Fin in the past. Thanks
