Radiant slab installation
Constantin
Member Posts: 3,796
In my house, the basement layers are as follows (bottom to top): Crushed stone, vapor barrier, 2" XPS foam, PEX tubing and steel grid, concrete.
Given what a long response time concrete has due to the very high thermal mass, maintaining an even temperature is not that big of a deal. Ideally, read <a href="http://www.heatinghelp.com/shopcart/product.cfm?category=2-2">Dan Holohans primer on radiant design</a>, it's a great introduction into the proper design specs, and why to chose one over the other.
The question of how to zone the basement should be asked the other way around: Do you have reason to believe that active microzoning is necessary in the basement due to inherent conditions, like a walk-out wall on one side, etc? In my basement, the temperatures are very even, despite just having one zone controller and a simple pump&manifold.
Radiant Slab Installation
Does the vapor barrier on a slab on graade installation go below the slab insulation or above the slab insulation? Also, what type of control scheme for the manifolds is prefered? Constant circulation manifolds coupled with a varible speed pump for mixing or installing telestats on all the manifold loops and having thermostats open and close them as required.?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
