Pipeing Design
bigugh_4
Member Posts: 405
diverter tees is not a good idea. Open and in the system they are not that big a restriction to water flow, Capping them off restricts the flow quite a bit. Engineer another way or remove them!
JMO
JMO
piping design
The system is 1 loop forced hot water that I am changing to 3 zones. There are 5 radiators down stairs and 4 radiators up stairs plus a 3 season room. When I change the piping should I remove the diverter t's from the original loop that are no longer being used? It would save a lot of time if I could just cap them off.
Thanks for any suggestions.0 -
You should be able to just connect the supply tee to the diverter tee parallel to the heating main wherever you disconnect a radiator. That will let the flow split as if the rad was still connected.0
