Buderus GB and indirect
Mark_7
Member Posts: 123
Has anybody used the GB wall hung with anyother indirect other than the buderus tank. Any flow problems?
should be no problem
I have not used that particu;lar boiler, but if you match the boiler with the proper flow rates of any other indirect, and the proper size of boiler, you will be fine, Its usually a habit/nice practice to keep manufactures items together, but I have seen them mixed and matched, Also might want to wire for hot water priority. Like stated earlier, compare requirements of indirect and make sure you can get enouh flow through boiler to accomodate indirect without going to a ridiculous size pump.0
