Adding a rad or baseboard
Bende Bessko
Member Posts: 9
The supply and return pipes that I can tap into are 1 1/2", both have unions, that branch off a 2 1/2" mains. These 1 1/2" supply and return pipes feed the 2nd and 3rd floors. No zone valves.
HELP on adding a rad or baseboard
The apartment company that I work for wants to add a rad or baseboard to a basement apartment. The heating system is a two pipe hot water system, an old gravity system that's been converted. There are pipes in the ceiling that I can tap into. Do I need special Tee's since I'm downfeeding? Any advice would be greatly appreciated!
Thanks,
BB0 -
Two Pipe
Need to see and check out the system to determine the correct hook up. Beware just plugging in could cause other problems....0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
