Buffertank,direct vent boiler & tekmar
KBP&H_3
KBP&H_3 Member Posts: 67
Has anyone done this setup on a baseboard system,, Honeywell Smile website lists all going into buffer tank,, after boiler,,, It would make sense to put the boiler first, pipe out to the buffer tank, and then the heating zones, putting the temp sensor for water temp after the buffer tank,,. W/ the pre and post purge on direct vent--- anyone have an idea for optimal boiler run time or tank sizing??? IE 100,000BTU out and 40 or 50 gallon tank???,,,
