Bill and Alex's excellent drop header, continued...
The Wire Nut
Member Posts: 422
Thanks to all of you who responded to the <A href="http://tinyurl.com/nzyys">previous post</A> on my new drop header. <small>(<A href="http://tinyurl.com/nzyys">Bill and Alex's excellent header</A></small>)
I was able to locate a 3" * 2" eccentric reducer. It is a beautiful fitting (my wife was much amused by my cooing!), nicely cast, with polished end surfaces, good sharp threads and all the casting detritus ground off. It was a thing of beauty... And it had better be as it was $45!
Here it is, installed...
I still have a lot to do, electric, water feed, fuel, controls and safety and venting.
Once that's done, I'll clean up the header and paint it black, a final touch that Mad Dog taught me...
On Wednesday I have a chimney sweep coming to check out the chimney and hopefully there will be no more toasted fowl. Should I have them put a cap on the chimney or is that a no-no?
With any luck, and Steamhead's help, I'll fire it up on Saturday. After a good cleaning, we'll settle back with a 6-pack of Cokes and enjoy the best heat you can sacrifice prehistoric crustaceans for...
Thanks again!
Thanks again!
"Let me control you"
Lost in SOHO NYC and Balmy Whites Valley PA
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
