Customer Concern, Dry Air
![[Deleted User]](https://secure.gravatar.com/avatar/cc317926fc2cf05b075c44a12a036ad3/?default=https%3A%2F%2Fvanillicon.com%2F99c18a05c95171d2be7c6133617c57e3_200.png&rating=g&size=200)
[Deleted User]
I have a customer who thought a hydronic heat fan coil
would rob less moisture from the air than a gas fired forced air furnace. The house is pretty tight, I would think that moisture goes in , moisture goes out on either one. Right?
Neither
will remove humidity so you are correct. The only way a warm air system can change the absolute or "specific" humidity in a house is by pressure imbalance whereby it draws in more dry outside air than normal infiltration would allow.
ANY house or space which is heated by any means from a cooler state will experience a drop in relative humidity as the air is able to hold more at warmer temperatures.
But either process in itself, going through a furnace or a hot water coil will not remove humidity, just "give it more room".0 -
Thanks for your input. Mike0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
