Tank Patch
Rookie_3
Member Posts: 244
Hello Gentlemen,
What would be the best oil tank patch that would be permanent, strong, and take some heat? I'm not trying to repair a bad tank. I need a quick fix that will hold up on the oil pan on my work van for a while until I have the time to replace or pull it and braze it. The tranny line was up against the side of the pan and bored a small hole in it that leaks 2 quarts before it is below the hole.Anything strong enough to hold back a couple hundred gallons of #2 should do fine against 5 quarts as long as it can take a little heat. Any thoughts would be appreciated. Thanks.............Dan AKA ROOKIE
Rookie,
i know you probably still find some dissagreement in my take on filling ot resumes buh overlook that for a momment.... when i moshed a hole in my oil pan on the dart ...a low riding pos i used to jet around in, i took some blue goo a short sheet metal screw with a dab on the threads brightened up the pan with a 1/2" cleaning brush ...screwed it down let it dry a day and ran it like that till i got a new pan. quick fix worked fine. there isnt alot of pressure in the oil pan...it is like a catch basin for the oil pump. well, in a pinch a sheet metal screw with a small rubber faucet washer would slow the stem of the tide also...just in case you are out in some distant drive to the nearest automotive blue goo vendor
Hey Weezbo, Thanks, I tried the sheet metal screw and it wasn't quite tight enough by itself. I almost hit it with some liquid weld over the screw. I'll give the blue goo a shot if it worked for you. Maybe the bue-goo on the screw and a rubber washer for the time being.
There wasn't any personal hard feelings over the resume threads just a lot frustration of not getting a shot at
something I like to work at (oil). I ended up with a
temporary job as a sub doing AC. 2 months later they wanted me to get on the books and a year and a half later I'm still there doing AC, some refridgeration, and a ton of heatpumps that will soon start failing more and more with the cool New England weather starting to set in. I still do as much of the oil calls as I can in the evenings and weekends. Translation....cleanouts and no heat calls on systems so outdated nobody else wants to work on them.
Anyway, thanks for the help. catch you later.........DAN
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
