Hey Hot Rod, What happened with that Prestige 110?
hr
hr Member Posts: 6,106
plugged it in, flipped the switch and it displayed and fired right up. Spent 2 hours cleaning and checking, and it continued to run without a glitch.
I must have had it in some sort of soft, hard, or over easy lock out:) I need to call up the factory and get more info.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Ross_7
    Ross_7 Member Posts: 577
    Prestige Electrical problem
    Hey Hot Rod,
    What did you find out on that Prestige 110, you were having problems with? Inquiring minds want to know!
    Thanks!
    Ross
  • LarryC
    LarryC Member Posts: 330
    Intermitent fault
    Intermitent faults are worst kind to find and fix. IF it goes off to la-la land again, check to see if any large electrical load just turned on OR off. I'm thinking a power spike might send it over the edge.
    Are there any electrical appliances nearby like real old refrigerators or freezers, old microwave oven, well pumps, central vacuum cleaner, etc.
    Are there any industrial equipment nearby like Welders, Compressors, Neon signs, etc.
    Is the furnace on its own DEDICATED electrical circuit?
    How is the building's electrical grounding? Poor grounding can cause all sorts of weird problems. Is there a grounding wire from the breaker panel to the METAL water main where it comes into the building? If the grounding wire attaches to the METAL water line after the shut off and meter, is there a wire jumper across the meter?
    Good Luck.
    Larry C
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    That old Midfas touch
    Dontcha just hate it when that happens. Time will tell if it will be a problem. I started up an LP prestige today without a glitch. Sweet. :) WW
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    if it is caused by other electrical loads
    coming on and affecting voltage, maybe a battery UPS unit would help ensure clean stable power if it becomes an intermittent pain in the butt situation.
    Cosmo
