Bob Sweet
Bob Sweet Member Posts: 540
Make sure to pay close attention to the primary and secondary piping diagrams, as well as the configuration of the pumps, with regards to location. That includes primary pump, secondary pump and indirect pump.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=443&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Boston
    Boston Member Posts: 71
    Thanks - Going to go with Mod/Con - Ultra
    Thanks to all for the help. Going with the Ultra 155(
    Also going with an indirect.
    I almost made a big mistake - I am winding up with a 155k mod/con and almost(without this site) got stuck with a C-I 250k unit.
    Any tips on installation? My guy said this morning that it needs stainless steel exhaust and that will add alot of $$$. Apparently here in MA all powervented boilers have to be 7' above ground level. That is a problem in itself....
  • John Reynolds
    John Reynolds Member Posts: 22
    In Mass you can vent to manufact Specs if you are under 7' above grade you needa sgn and co dectector hardwire with backup etc etc
  • Kevin_45
    Kevin_45 Member Posts: 1
    That don't have to be 7 feet
    But if they are lower you have to have a CO detector hard wired on the same floor near the boiler. battery ones on each above. And a sign stating gas vent directly below , keep clear of obstruction attached to the house, directly above the vent, and 8 feet above the ground.
    I am not familiar with the wm ultra so can't help you there
    All the best
    Kevin
  • Tony_23
    Tony_23 Member Posts: 1,033
    No SS
    He'd better read the installation manual, the Ultra vents w/ PVC
  • John Reynolds
    Last time I did an Ultra it was vented in PVC pipe you should ask your installer more questions
  • Floyd
    Floyd Member Posts: 429
    Go here....
    and down load your own copy of the installation manual... you'll probably know more than the contractor..... he put the manual by the toilet, and NOT to be used for reading material either....:-) Make SURE he follows the piping instruction to the T!!!!
    Don't live in Mass. so I can't say about their code, but I'm sure that a creative mind could find plenty of ways to get around that.....
    http://www.weil-mclain.com/FTP/Ultra 310/UltraBoilerManual.pdf
    Floyd
