FYI
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in
cooperation with the firm named below, today announced a voluntary
recall of the following consumer product. Consumers should stop using
recalled products immediately unless otherwise instructed.
Name of Product: Delta Performance or Delta Performance Plus Series
Combination Water Heaters
Units: About 3,000
Manufacturer: Triangle Tube/Phase III, of Blackwood, N.J.
Hazard: The burner plate and flue hood seal on the water heaters can
fail due to an improper seal causing a leak of flue gases and carbon
monoxide (CO). This poses the risk of CO poisoning to consumers inside
of the house.
Incidents/Injuries: Triangle Tube has received one repor! t of a flue leak
with the recalled Combination Water Heater during installation. No
injuries have been reported.
Description and Models: The recalled Delta Performance or Delta
Performance Plus Series Combination Water Heaters operate on natural or
propane gas. The water heaters are white and rectangular. "Triangle
Tube" is written on the silver-colored control panel. "Delta" is printed
on the front of the water heater. The burner is located under a white or
gray cover that protrudes outward at the bottom front of the heater. The
models and serial numbers included in this recall are listed below. The
model and serial numbers are located on the rating plate on either the
front or the right side of the water heater.
Models Serial Numbers
PG-25 1148
PG-30 through
PG-35 6203
PG-40
PG-45
PG PLUS-25
PG PLUS-30
PG PLUS-35
PG PLUS-40
PG PLUS-45
Sold at: Plumbing and heating wholesale! compan ies to independent
plumbing and heating contractors from August 2001 to January 2006 for
about $3,500.
Manufactured in: United States
Remedy: Consumers should immediately stop using the recalled water
heaters and contact Triangle Tube to schedule a free repair.
Consumer Contact: For more information, contact Triangle Tube at (800)
856-6271 between 8 a.m. and 4 p.m. ET Monday through Friday, or visit
the company's Web site at www.triangletube.com
To view this release online, please go to our web site at:
http://www.cpsc.gov/cpscpub/prerel/prhtml06/06252.html
Yours, Larry
  • Weezbo
    Weezbo Member Posts: 6,231
    This is a good company...
    i think that this is important information that they would want disseminated as rapidly as possible along with the solution.
    public awareness helps gets things done.
  • John F
    John F Member Posts: 29
    Delta Recall
    I have one of the Delta units in my home. Triange Tube sent me a notice 2 months ago and has sent me a free repair kit. I think that anyone who has registered their heaters with Triangle Tube has received notice. Triangle Tube is on top of this and is very responsive to, and supportive of, their customers.
