steam system two pipe question
clammy
clammy Member Posts: 3,256
I have ran into a few jobs where the traps where located remotely in the basement and this was for not only the first floor but the second who knows the reason this was on a trane system .As ken stated pull the unions off on both the supply and returns if you find a brass insert possibable on the inlet and no trap on the outlet they may be metering the correct amount of steam into the rad that it could condense thus the rad there fore not needing a trap but the system must have a vapor stat on it to operate properly , your system could also have small water seal traps like brommwells they look like a funny return ell or maybe are all your returns dropped below the boiler water line then it just each rad dripped to the wet return do you have any air vents on any rads ?be nosey and look it's much better always to look before you leap peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
