Your input on snowmelt.
hr
Member Posts: 6,106
to keep ice from forming. Generally you don't design to heat the space, just keep the slab ice free and safe to walk on. Without knowing how many loops and the area square footage, hard to answer your question.
Will it work! Quite possible. Is it a professional install? Debateable from what you indicate.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Will it work?
OK I will try to get pics soon. Here's the skinny. Car wash snow melt. 180 FT loops on 6"-18" centers( no real pattern on spacing). 5" slab big drain in the middle 3X4 with no extra tubing around it all on pea gravel W/O insulation. close to the walls is single 10" spacing right close to the hoses where they drip. Design temp is 0 plus wind. This job was bid by us then was given to the lowest bid. All I can say is you get what you pay for.If I forgot anything let me know and I might be able to tell you.
sure it'll work
Sure it'll work with oversized bolier connected to non meter gas supply...0 -
Expect...
Striping...
Hydronics, including the sub category of snowmelt systems is EXTREMELY forgiving to ignorance...
At least they have THAT going for them.
ME0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
