weil mclain output rating
Todd_12
Member Posts: 55
If there is a CP number still on the boiler, you can find out exactly what you have.
It sounds like you you probably have a 468. This boiler is rated at 465 sqaure feet of steam and 111.8 net steam mbh. You can look under obsolete product literature at www.weil-mclain.com
I have a Weil Mclain 4 section steam boiler (oil) which is about 15 yrs old and has no tag anywhere to be found wanted to know what how to find the btu input/output. Is there a rule of thumb number of BTU's per section?
-JB0 -
Weil 468
is rated at 465 Sq/ft.This is irrelavant to sizing a new boiler which is done by sq/ft of radiation, not heat loss of house
can you
Can u post pcture of it?0 -
would depend on the current nozzel size and pump pressure
....... sounds trite i know however if there is a retro fit burner it would be enlightening. if you have like you can compare like to like....0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
