Radiant Walls
Joe_76
Joe_76 Member Posts: 34
I am thinking of installing radiant walls around a 3ft deep by 5ft round conventional tub. There is a circular stub wall around it for 180 degrees and an exterior wall on the other side. The biggest problem is that it is in a corner below two 5ft by 5ft windows. I would like to install radiant in the stub wall to help heat the whole room and to heat the tub. Any thoughts or suggestions?
Thanks Joe
  • Never thougt I'd say this...
    but I'd suggest you go with a low watt radiant product. Like Watts Heat Weave or the like.
    Unless you have lots of time and an immediate access to a good hydronic heat source of course:-)
    Fast response, no potential of leakage, don't mind if it gets holes poke in it, easy to control (twist timer).
    There ARE special applications for electric radiant. Fer sure.
    ME
  • hr
    hr Member Posts: 6,106
    I've done circular walls with transfer plates
    use the 3/8" size foir tighter bends. if you go with electric mat or cable check about wet location restrictions.
    hot rod
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    heresy, the inquisition commences
    I can't believe I read those words from one of the founding wetheads! ;)
    Who's next Hot Rod? Uh oh too late
    Well I guess, it is any day now that Steamhead will recommend converting from steam to anything else...........
    Well before I ride off into the sunset on my high horse...
    I have a small electric radiant bathroom under my belt. Heat pumps and limited budgets are real buzzkills!
    Cosmo
