Multi fuel stoves and boilers
Mike T., Swampeast MO
Member Posts: 6,928
Only based on the size of the radiators if this is steam.
If water, it's based on the heat loss of the structure.
Heating of 10 radiators using multifuel stove
I want to install a multifuel stove burner to run 10 radiators.
What boiler or heating out put will i require, and is this based on size of the Radiators.
Can you give me a formula to work out the out put? Thanks0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
