Buderus G115
Robert O'Connor_8
Member Posts: 53
I use Riello's Becketts and Carlins in different applications. Ibelieve you would find the most reliability with the Carlin in the set up you describe.
All the best
Robert
ME
All the best
Robert
ME
I have read on another forum that there may be a problem with buderus direct vent and reillo burners. I am having a G115 installed this spring with the option of outside air intake and chimney exhaust. Are there any problems with this arrangement? or am I better off using boiler room air for intake. I wanted to have the least amount of noise from the boiler/burner. Thanking you in advance.0 -
noise
I have found the BF and F series are both quiet with a chimney set up.I perfer the F series over the BF for ease of setting a perfect fire.I would use the BF in a linty/dusty/dirty boiler location
or need to with Direct Vent...0 -
Beckett NX
I have a Beckett NX in my G115-4, it has run flawlessly and is absolutly silent. I think it can be used for direct vent.0 -
hanging circ
I don't mean to butt my nose in, but it appears there is a Pink circulator in the back of the photo that is installed in a hanging positon. For what it's worth, that should be corrected ASAP, as there is no faster way to burn a wet rotor circulator out than installing one in that position.
Just some friendly advice. jw0 -
Direct vent
I would not recommend a direct vent 115. There is a problem with the system misfiring during operation. I have been having problems with my system for over two years with no proper fix in site.0 -
one job
I used a buderus g115-4 dv with a beckett nx, I had a few no heat and no hotwater calls, this past winter. Everything was set up, perfect, very quiet.
can't figure what it is ,nozzles were change each time, everything clean.
But if happens again, I think I'll eat it and replace the burner with a riello.
Talked to another contractor, same boiler/burner, same problem, he replaced burner with riello.
NX very sensitive, make sure adjustment is right-on, I believe it was 2.5 .
Beckett NX
I have noticed that on the NX burners have a little trouble sensing the flame on the low firing rates. You may want to check the ohm reading on the primary, it should have the 7100 series primary that will tell you the resistance by the push of a button. I put one of the new MPO147DV's in with a NX in February and it was impressive.0 -
Buderus/Riello
Thats a great combination boiler/burner, first a question is this unit vented to a chimney? Which Riello Burner is on the boiler? An lastly what conditons are like in the cellar?Once I know those answers I can tell you which way to go?0 -
J.V.M.
It will be vented to a chimney. The basement is semi-finished. The boiler will be in an unfinished room app. 8'X 9'. The laundry room will be close to the boiler room - dryer is a Fisher-Paykel and it appears to exhauast a lot of air compared to dryer I removed. Beyond that I don't use the basement much and it would appear not to be as clean as the rest of the house. I don't know which Reillo will be installed by the installer but I am not locked in to any as yet. Hope this helps. Thank you. Rich0 -
Buderus
Has anyone had problems with Buderus H W biolers models # GB-142 or GA- 124?0 -
new
You should start a new topic, bob K. You may get more answers.
g115
Gentlemen as you all know that when it comes to oil burners that they all work differently in different enviroments. I would have to say that it all depends on the installer and what his preference is to what burner he is going to install. I think that all the becketts, riellos and carlins are a good burner as long as the tech takes the time to set it up to the enviroment that it is in.0 -
Thanks for the answers, with the Buderus installed intro a chimney there is thhe possiblity of combustion sound. But I have found that in setting up the Riello burner, you can quiet it down but setting to the Riello specs, not Buderus specs. Also use a 60degree W nozzle. this soften the flame.The 60degree B type nozzle will give you more combustion noise. Set the burner for 10-12.5% co2. Hope this helps. ,JVM0 -
I have been using a G115-21 with a Riello BF3 in direct vent for years with no problems.0 -
Buderus/Riello DV
I have quite a few of these combo's out there. The "problem" is that with extremly cold air they tend to develop carbon on the heads, causing no heat calls. I use the seperate hoods,ie aero-cowl with the combustion air intake. If the intake is longer and the basement warm it's less of a problem. Also I've been openinig the vac. breaker to mix some warmer basement air with the outside intake air. All my equipment is set to spec and tested with a Testo so improper set up is not a issue. I have converted 1 such combo to the Carlin burner to see if it resolves the issue.0 -
Keep us posted
Captn,
If you could keep us posted, I would like to hear your results. I have seen quite a few DV's with both the Riello's and the Carlins working in the field, and look forward to hearing your experience.0 -
Will do but.....
I'm in the spring summer months so I'll have to wait for cold air again....................0 -
Capt'n
I read the other day and I will try to find it that to resolve the Carlin cold head was to increase pressure to 180psi and of course decrease the nozzle, that was from Carlin0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
