Fan in the can my Man!
John_105
Member Posts: 15
Any one have any good recomendations, tips, best practices or prefrences for a fan in the can? See this one http://www.pureairplus.com/nap.htm
I need something to supply air to two gas steam boilers, two hot water heaters, and a gas dryer that vents a lot of air out in a basement... The one in the article lloooks a bit fancy , and it looks like it supplies air to a forced hot air system heater....Any info or any gotchas to look out for would be great!
also, anyone doing any geothermal heating systems?
Thank you so much,
Bill,
Thank you so much,
Bill,
here is some good info for what I am up against. Caulking of windowss... http://lancaster.unl.edu/home/IndoorAir/Gases.htm0 -
fan in a can
are you saying the gas dryer vents into the basement? field controls makes the fan in the can that can be used with multiple appliances
Tjernlund makes a good commercial unit
Sounds like that's what you're looking for. We put one in last year for a 250K input boiler in a mech room that had no outside walls. Pretty nice system. You could configure it for multiple appliances.0 -
Bill the pureair unit is to add outside air to make air changes in a warm air heating system what you are looking for is a unit like the fan in the can http://www.fieldcontrols.com/cas3-4.html0
- 86.7K THE MAIN WALL
- 57 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
