Steam boiler Hot Water coil
Guy_6
Member Posts: 450
It sounds like the tempering valve, sometimes known as the mixing valve, is not functioning. Perhaps some debris became lodged in it during the changeout. The aquastat will only regulate the hot water temp. when there is no call for heat. When the boiler is making steam, it is up to the mixing valve to add cold (domestic) water to the hot (domestic) to obtain the correct temperature.
Steam Hot Water coil too HOT
in 35 year old model 572 steam boiler. About a year ago the coil was removed in order to replace a leaking gasket. What would make the hot water reach steam temperatures? This occurs after the boiler has been chugging at full tilt for a while.0 -
in 35 year old model 572 steam boiler. About a year ago the coil was removed in order to replace a leaking gasket. What would make the hot water reach steam temperatures? This occurs after the boiler has been chugging at full tilt for a while. What could have changed to make coil now way to hot?? Alfred/Jim
PS: aquastat was set too 150, but is now set to 140 with same result, steamy hot water.0 -
instant tea & coffee
looks like you have no proper tempering valve just a primitive globe valve bypass set-up. not a very sophisticated piping arrangement. the globe valve is makeshift at best, useless at worst case scenario. remedy : repipe properly before someone gets scalded. you could probably make tea straight from your faucets.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
