Main vents
tom_11
Member Posts: 58
I have a one pipe steam system, with 17 ft of 1.5 pipe what would be the best size vent. I can only put it on the side of the last fitting because it is to close to the concret wall.
Use
a Gorton #1 or Hoffman #75. Is this the only steam main in the system?
Main vents
The other main is 15 ft of 1.5 ,i have a gordon 1 on it . Would drilling and tapping a half inch hole, on the side of the fitting be safe, as not to crack the fitting. Thanks tom0 -
That
should work fine. Make sure you pitch the tapping up from the tee slightly so water won't collect in the pipe.
main vents
Steamhead, Thanks for the good info . tom0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
