boiler pictures
rick_33
Member Posts: 20
sORRY ABOUT PICTURES ,THE SUPPLY AND THE RETURN AR PIPED TOGETHER AND THEIR IS TWO CICULATORS ,ONE THERMASTAT RUNS BOTH .I dID NOT PIPE ARRANGEMENT . jUST THOUGHT i PUT IT ON THE WALL . 2 FAMILY HOUSE , THAT HAS BEEN CONVERTED TO TWO SYTEMS.
boiler piping
what do yo find wrong with this piping, any help?0 -
well I can't
really tell from the pictures per say but what is the boiler hooked up to? Looks like a lot of condensation...probabaly hooked to a lot of standing CI rads w/o any boiler protection. I wonder what the combustion chamber looks like....kpc
Shrink the picture!
Having shrink the picture down so that it can be viewed for all to see, I see what appears to be an extremely damp basement or a G-115 that is in the process of dying a slow and miserable death. I also see an attempt at primary-secondary boiler piping. I see what appears to be two system zone pumps above but you can't really tell what is going on up above with all of the black plastic covering everything up.
Glenn Stanton
Manager of Training
Burnham Hydronics
U.S. Boiler Co., Inc.0 -
well.... maybe you have alot of leaks or....
the pipe busted somewhere when along the line. you can be sure that without any temp gages on the return ,there is no really Great way to figure out what is actually happening or when. my thought would be to further isolate the boiler from the "field" with a modulating setpoint control or pump logic ....and put some gages on the supply out to the Field,...... and the return above the lowest T of the new bypass. then i'd likely go for partial differential reset for GP's and get a handle on the zoning of that system.0 -
pics
looks like the feed is piped into return, air scoop in wrong location, circulator in wrong spot, tape on the smoke pipe, hey is this a trick pic?0 -
Agreed!
Serious piping errors and condensation to boot. Buderus would not be happy with this and the installation will affect factory warranty. This boiler needs a repipe, correct controls and a bypass.
where is...
this install? kpc
G115
It's hard to get a total look at the near boiler piping due to the pipe wrapping, but as others have mentioned, a proper by-pass is needed on this large mass system. What did the inside of the boiler look like? How old is the system? Is the homeowner willing to hire you correct this? You are correct about the warranty might be void if left this way. Thanks to all who contributed!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
