Wiring Issues
jim lockard
jim lockard Member Posts: 1,059
1)Neutral and ground must be isolated to the point of service. That means to the main panel box. If you are using a subpanel you must bring the ground back seperate. So yes to main panel/ no to subpanel
2) 20 amps
3)How about a fused pullout at the appliance, gives you overcurrent protection and a disconnect all in one.
J.Lockard
Welcome
It looks like you're new here. Sign in or register to get started.
